Charlo Posted December 27, 2015 Share Posted December 27, 2015 · Hidden by Flint13, December 27, 2015 - No reason given Hidden by Flint13, December 27, 2015 - No reason given I wonder how gravity smells.Like victory. Like Dubstep sounds. On the Choom debate it is personal preference really. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4261712
RandomMarine Posted December 27, 2015 Share Posted December 27, 2015 · Hidden by Flint13, December 27, 2015 - No reason given Hidden by Flint13, December 27, 2015 - No reason given Like this https://youtu.be/SM2J0gb_j-8 Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262060
Brofist Posted December 27, 2015 Share Posted December 27, 2015 Personal, I'd rather spend those 10 points somewhere else. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262274 Share on other sites More sharing options...
Terminus Posted December 27, 2015 Share Posted December 27, 2015 (edited) Volkites can be seen as a 30" Heavy 8 S6 weapon. If you can't find a use for that, something's wrong with you. S6 hits harder, and with AP4, against an MEQ list, those saves are still going to be made - except that the Calivers not only force a higher ratio of hits (unless your opponent miraculously lets his guys clump up before hand, the 32mm bases now provided are a slight PITA for this. But a S5 Autohit template is going to have to put some effort into getting all of those models under the template, and then has a harder chance of wounding. I think that without a doubt, the Calivers are better, but whether they're worth the 10pts is questionable. They're a neat upgrade if you have the points, but can forego them should you need to strip points back. Of course, the Choomclub are going to ask for my membership card back now, but... It's only Heavy 4 since they are calivers, and the AP4 of the Heavy Flamer matters quite a lot specifically against the targets I mentioned (Solar Auxilia and high-tech Militia), particularly since it also ignores cover. Against Marines, it really doesn't matter either way, except one option is cheaper. You do get the lulz potential of deflagrate if your dice are hot and the opponent's aren't, and the 30" range gives a foot-slogging Levi something to do. If it was Heavy 8, it would be a no-brainer alongside a pair of Storm Cannons. Edited December 27, 2015 by Terminus Brofist 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262284 Share on other sites More sharing options...
Hesh Kadesh Posted December 28, 2015 Share Posted December 28, 2015 No idea what I was thinking when I wrote heavy 8. I wasn't even thinking of Culverins as I clearly wrote Calivers later. Ah well. The 30" range isn't wasted even on a Podded Dread, though. If you take Flamers, then you're going to need a Pod to bring them. Killing SA and Militia is easy - It's 30k. You tie them up in CC. Congratulations. You can use the Pile in move to drag enemies off of an objective too, and they can't hurt it, so they must fall back. Still, if you're having trouble getting wounds down on the table (such as in an Alpha Legion Drop Pod Assault List), then I suppose that a Levi is a good option there. That's it's cheaper doesn't hurt. Against Marines, you have higher strength, longer range shooting coming down in a pod. Can help crack a Predator, Rhino or even a Vindicator's rear armour (especially with +1 to damage as an AL Dreadnought in Dynat lists). Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262581 Share on other sites More sharing options...
Terminus Posted December 28, 2015 Share Posted December 28, 2015 Uh, tying up SA and Militia is a horrible idea if your plan is to tie up 100-point unit with a 300+ Leviathan, and playing right into your opponent's hands. That's why I rather just roast them, and make assault a losing proposition as the heavy flamers eat 2D3 of them as they try to tie YOU down. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262827 Share on other sites More sharing options...
Slips Posted December 28, 2015 Share Posted December 28, 2015 The thing is, aside from fearless cultist levy blobs which you actually do want to flame, the mortal armies dont really have much access to Fearless Bubbles. Meaning if they assault the leviathan or you assault into them, them lacking the gear to harm Av13 means that their inly recourse is to use "our weapons are useless" and fall back or to have a few die, run away and get swept. I honestly dont think anyone here would be foolish enough to run a Leviathan into a fearless tarpit. Terminus 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262834 Share on other sites More sharing options...
depthcharge12 Posted December 28, 2015 Author Share Posted December 28, 2015 · Hidden by Flint13, December 28, 2015 - No reason given Hidden by Flint13, December 28, 2015 - No reason given The thing is, aside from fearless cultist levy blobs which you actually do want to flame, the mortal armies dont really have much access to Fearless Bubbles. Meaning if they assault the leviathan or you assault into them, them lacking the gear to harm Av13 means that their inly recourse is to use "our weapons are useless" and fall back or to have a few die, run away and get swept. I honestly dont think anyone here would be foolish enough to run a Leviathan into a fearless tarpit. "TEH FEWLS! TEH COWARDS!!! THEY HIDE IN METAL BAWKSES! SIIIIIINNNNDRRIIII!" Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262839
ThatOneMarshal Posted December 28, 2015 Share Posted December 28, 2015 Remember that when they do ours weapons are useless checks, you can and will sweep them. An interesting tidbit I found playing against the chaos space marines. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262867 Share on other sites More sharing options...
Terminus Posted December 28, 2015 Share Posted December 28, 2015 The thing is, aside from fearless cultist levy blobs which you actually do want to flame, the mortal armies dont really have much access to Fearless Bubbles. Meaning if they assault the leviathan or you assault into them, them lacking the gear to harm Av13 means that their inly recourse is to use "our weapons are useless" and fall back or to have a few die, run away and get swept. I honestly dont think anyone here would be foolish enough to run a Leviathan into a fearless tarpit. You would think, but these things happen in Drunkhammer. :P Brother Aiwass and Slips 2 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262870 Share on other sites More sharing options...
Slips Posted December 28, 2015 Share Posted December 28, 2015 ...true dat. Alcohol tends to make us go from "Hmm, sound plan, commander." to "FETH IT! BALLS TO THE WALLS BOYS! CHAAAAARRRGGGEEE!" rather quickly ^_^ Plaguecaster 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262872 Share on other sites More sharing options...
depthcharge12 Posted December 28, 2015 Author Share Posted December 28, 2015 · Hidden by Flint13, December 28, 2015 - No reason given Hidden by Flint13, December 28, 2015 - No reason given The thing is, aside from fearless cultist levy blobs which you actually do want to flame, the mortal armies dont really have much access to Fearless Bubbles. Meaning if they assault the leviathan or you assault into them, them lacking the gear to harm Av13 means that their inly recourse is to use "our weapons are useless" and fall back or to have a few die, run away and get swept. I honestly dont think anyone here would be foolish enough to run a Leviathan into a fearless tarpit. You would think, but these things happen in Drunkhammer. :P If you love Drunkhammer, you should play Irishhammer ;) it's like Drunkhammer, without the Hammer... Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262880
Raktra Posted December 28, 2015 Share Posted December 28, 2015 I hope the Heresy gets horse-mounted cavalry so I can have my Leviathan live up to my Geordie heritage and punch a horse in the face.Tactics note, in 1500pts should I endeavour to fit in a pod for one, or just footslog and pray? There's no D-spam in my GW. KJB and Reyner 2 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262885 Share on other sites More sharing options...
Slips Posted December 28, 2015 Share Posted December 28, 2015 Pretty much always pod it unless your running a Talon, imo. Even without D spam, its not a super-heavy and is thus susceptible to failing the occasional 4++ vs an Explodes Result. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262886 Share on other sites More sharing options...
Hesh Kadesh Posted December 28, 2015 Share Posted December 28, 2015 Uh, tying up SA and Militia is a horrible idea if your plan is to tie up 100-point unit with a 300+ Leviathan, and playing right into your opponent's hands. That's why I rather just roast them, and make assault a losing proposition as the heavy flamers eat 2D3 of them as they try to tie YOU down. Why? Pull them off the objective with the Pile in and put in a unit who can score, swing of +2 vps. Obviously don't go after one that you can't. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4262896 Share on other sites More sharing options...
01RTB01 Posted December 29, 2015 Share Posted December 29, 2015 At 1500 it's a fifth of your points. Depending on loadout I'd run and no pod. There's not that much you can fit into 1500. I think the leviathan is incredibly resilient. Add in ceramite and there's little that can pop it. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263189 Share on other sites More sharing options...
Booth Posted December 29, 2015 Share Posted December 29, 2015 I was wondering if anyone has tried out the new(ish) Leviathan Dreadnought, or just had any opinions on it. Looking at it I find I could easily justify including one in game, but I have a soft spot for Dreadnoughts. The rules are provided for free on the Forgeworld website on the model's page, but here's the link to where they provide it (sorry if this breaks any rules): http://www.forgeworld.co.uk/resources/PDF/Datasheets/LeviathanSiegeDreadnoughtRules.pdf Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263223 Share on other sites More sharing options...
Brofist Posted December 29, 2015 Share Posted December 29, 2015 (edited) · Hidden by Flint13, December 29, 2015 - No reason given Hidden by Flint13, December 29, 2015 - No reason given ++ Link No longer Required ++ Edited December 29, 2015 by Slipstreams Merged Topics. Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263227
Slips Posted December 29, 2015 Share Posted December 29, 2015 Merged. Thanks Bulba! Brofist 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263245 Share on other sites More sharing options...
dark_elf Posted December 29, 2015 Share Posted December 29, 2015 Has anyone tried out a list with Leviathans? Was thinking of something along the lines of: 2 x Leviathans with DDP 2 x Contemptors with DDP 2 x Troops Tax 1 x Delegatus to open up Rites of War 2 x 3 Jetbikes Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263254 Share on other sites More sharing options...
01RTB01 Posted December 29, 2015 Share Posted December 29, 2015 What's DDP? I've played my leviathan in a couple of games and I won't look back. I run claw, drill, phosphex and choom. Its incredibly sturdy due to the 4++ and the 4 hull points. Amazing that they can be taken in talons! The fact that they're very popular (warning on fw website for delivery) would suggest people are v happy with them. To me they play as dreads "should do". I'd run a full talon of them if I had the points! Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263277 Share on other sites More sharing options...
Slips Posted December 29, 2015 Share Posted December 29, 2015 DDP = Dreadnought Drop Pod. 01RTB01 1 Back to top Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4263281 Share on other sites More sharing options...
Lord Blackwood Posted January 5, 2016 Share Posted January 5, 2016 So Bombard and Claw or Bombard and Drill ( if you can only pick one or the other ) Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4268904 Share on other sites More sharing options...
Raktra Posted January 5, 2016 Share Posted January 5, 2016 Personally I prefer claw as an anti big thing measure. Least there's a chance to blow up a vehicle you punch. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4269028 Share on other sites More sharing options...
Charlo Posted January 5, 2016 Share Posted January 5, 2016 Meta dependant. I prefer the armour bane as you will just wreck any vehicle rather easily. The extra wound claw seems a little too niche unless you fight a lot of MC/ Primarchs. Link to comment https://bolterandchainsword.com/topic/315048-leviathan-siege-dread-tactics/page/10/#findComment-4269039 Share on other sites More sharing options...
