thewarriorhunter Posted August 28, 2018 Author Share Posted August 28, 2018 (edited) I wasn't implying it was jammed, but that it was out of ammo. I do really like Bjorn's idea. I was thinking of orientation too, that side has to go up because the other side is messier from chopping off the hand while trying to retain the grip. This is to get the idea off. Trust me I think of the details. I was even thinking of moving the tab that is the Bolt Carrier Group to the back if I hollowed out the mag well to show it locked in place when empty (as most modern firearms do). I could add a chain sword that is lodged into it... My concern is that I know have a lot of stuff jammed onto a 32mm base. I could cut the chain sword down so that only a stub of the end is on the base. That would then tell the story of the marine cutting it in two as he made space with his enemy to draw and fire his pistol. I could take a piece from one of my son's Lychguard sprues... hrm... given that we're getting into KT together it might make thematic sense for my KT to have necron bits on their bases... Edited August 28, 2018 by thewarriorhunter Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5155482 Share on other sites More sharing options...
9x19 Parabellum Posted August 28, 2018 Share Posted August 28, 2018 The weapon is lying in a perfectly reasonable spot. Consider the right hand secures the weapon by the pistol grip and the left hand usually grasps it by the furniture that's built up around the barrel. If you ran out of ammo and had to draw your back up weapon, the first thing you'd let go of is the pistol grip. which would free your dominant (right) hand to immediately draw your pistol. If you wanted to retain custody of your rifle, you'd keep it in your left hand, grasped, again, by the furniture around the barrel, which is not only the default place to hold it after you let go of the pistol grip, but also the natural center of gravity of the weapon (or close enough to it). Now then, and here's the key; once you realized you were out of ammo, or, for whatever other reason, realized you had to drop the rifle to draw your power sword, you would have dropped it from the left hand. Thus, the position it's lying on the base is perfectly logical and reasonable with the assumption of a left-hand drop from a forward carry/tactical position Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5155543 Share on other sites More sharing options...
thewarriorhunter Posted August 28, 2018 Author Share Posted August 28, 2018 I appreciate the technical detail and analysis because I had similar thoughts go through my head. Ultimately I can place it however because: in the swirling din that is a close range firefight the rifle would not be dropped statically. The marine would be moving during all of this and depending on what direction/level of force was being applied that will affect the final position. I could take a rifle and drop it straight down on the stock 10 times and we'll probably have 10 different positions from minor nuances of lean angle. On another note I got the second AGL mostly done last night. I need to clean it up and sand a few edges down but I was waiting for the glue to set before I did any of that. Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5155591 Share on other sites More sharing options...
thewarriorhunter Posted August 29, 2018 Author Share Posted August 29, 2018 OK. As much as I LOVE the idea of the damaged bolt rifle I think it will be too much for the base. Maybe if it was on a 40mm I would feel better about it. I think I may go for this look here: Hidden Content Hidden Content Hidden Content I watched some scale modeling videos and think I'll be able to build a sling out of masking tape or foil. I'll remove the magazine so the weapon appears empty. duz_, NiceGuyAdi, Race Bannon and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5155925 Share on other sites More sharing options...
Dracos Posted August 29, 2018 Share Posted August 29, 2018 much better than laying at his feet imo. thewarriorhunter and Race Bannon 2 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5155926 Share on other sites More sharing options...
W.A.Rorie Posted August 29, 2018 Share Posted August 29, 2018 that looks better Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156192 Share on other sites More sharing options...
thewarriorhunter Posted August 29, 2018 Author Share Posted August 29, 2018 In a FB group I've been posting in I had several replies of Marines being able to Mag-lock their rifles to their armor. I've only read a handful of books and that hasn't come up yet. I'm wondering if I should forego the sling and stick to lore or if a sling would help with the overall presentation... duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156211 Share on other sites More sharing options...
W.A.Rorie Posted August 29, 2018 Share Posted August 29, 2018 Sling....it just gives it the tacticool feel Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156226 Share on other sites More sharing options...
thewarriorhunter Posted August 29, 2018 Author Share Posted August 29, 2018 That's what I'm thinking. I have to find some masking tape at work today and take a few strips. I only have painters tape at home. Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156240 Share on other sites More sharing options...
duz_ Posted August 29, 2018 Share Posted August 29, 2018 Mag-locking is a thing I've read about magazines, although I can't recall Bolters.I'm sure they can? A sling wouldn't hurt though! ;) Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156256 Share on other sites More sharing options...
thewarriorhunter Posted August 29, 2018 Author Share Posted August 29, 2018 I think I recall reading about reloads with mags in some of the HH novels but they never mention where they pull them from. you don't see them modeled on the guys and no one has a drop bag for their empties. Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156285 Share on other sites More sharing options...
W.A.Rorie Posted August 29, 2018 Share Posted August 29, 2018 (edited) In the "Dark Imperium" they mention the primaris marines mag locking bolters on to their armor and I know in "Faith and Fire" the Celestians for the adepta Sororitas do it too. I think they drop the empty mag and leave it be. Littler Bugs! Edited August 29, 2018 by war009 Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156358 Share on other sites More sharing options...
robofish7591 Posted August 29, 2018 Share Posted August 29, 2018 Mag locking is definitely a thing, although I think a sling would look the best as it looks more realistic. Bjorn’s onto something. Implying a Bolter would jam is heresy, so being made damaged in battle makes sense.I’d maybe think about how it’s oriented next to the marine. It seems an odd way to land if he’s dropped it. Have you played Space Hulk? Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156374 Share on other sites More sharing options...
NiceGuyAdi Posted August 29, 2018 Share Posted August 29, 2018 Not since I was 11! (Hint, that was early nineties) WarriorHunter, If you go down foil/tape slings and you’re happy with it it’s be good to get a how-to. I’ve made them out of green stuff: sling loose from the rifle is easy and looks good; slung over the shoulder I found much harder. robofish7591 1 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156398 Share on other sites More sharing options...
thewarriorhunter Posted August 29, 2018 Author Share Posted August 29, 2018 Rolling pin came in, looks awesome and I am stoked about the detail that's in it. Coffee cup for scale: Hidden Content Hidden Content It's big enough that I could do a knight base, which might happen since the story that I am creating in my head has the Spectral Sicarii running across a knight in their adventures... Race Bannon, NiceGuyAdi, duz_ and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156406 Share on other sites More sharing options...
Race Bannon Posted August 29, 2018 Share Posted August 29, 2018 Mag-lock? Did anyone think Starcom or was it just me ... W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156502 Share on other sites More sharing options...
thewarriorhunter Posted August 30, 2018 Author Share Posted August 30, 2018 Play-Doh test run, very cool. The roller is large enough that it will easily cover a knight base... and I conveniently have two of them on sprue still... Hidden Content Race Bannon, W.A.Rorie, NiceGuyAdi and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5156704 Share on other sites More sharing options...
W.A.Rorie Posted August 30, 2018 Share Posted August 30, 2018 Have you played Space Hulk? SERGIO's BOLTER is Jammed.....Every freaking time Sergio Every freaking time I even gave him a Heavy Flamer and he still yelled "Sergio's bolter is jammed" Mag-lock? Did anyone think Starcom or was it just me ... Lol duz_, robofish7591 and Race Bannon 3 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5157287 Share on other sites More sharing options...
Bjorn Firewalker Posted August 30, 2018 Share Posted August 30, 2018 Mag-lock? Did anyone think Starcom or was it just me ... The fact I even remember the toy line and its accompanying cartoon, makes me feel old. Race Bannon 1 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5157487 Share on other sites More sharing options...
thewarriorhunter Posted August 31, 2018 Author Share Posted August 31, 2018 (edited) DIY Sling done! I'll have process pics up eventually but I'm stoked with how well it turned out: Hidden Content Edited August 31, 2018 by thewarriorhunter NiceGuyAdi, W.A.Rorie, robofish7591 and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5157732 Share on other sites More sharing options...
duz_ Posted August 31, 2018 Share Posted August 31, 2018 Looks good what did you use? Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5157924 Share on other sites More sharing options...
ShinyRhino Posted August 31, 2018 Share Posted August 31, 2018 Leave the magazine attached. No self respecting war fighter throws empty mags on the ground. You only get issued so many, and when it's time for resupply you can't reload mags you left in the sand two klicks away. robofish7591 1 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5158011 Share on other sites More sharing options...
W.A.Rorie Posted August 31, 2018 Share Posted August 31, 2018 yes give us the recipe thewarriorhunter......RACE BANNON COMMANDS Thee.....or he will shortly duz_, Race Bannon and thewarriorhunter 3 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5158040 Share on other sites More sharing options...
robofish7591 Posted August 31, 2018 Share Posted August 31, 2018 That is a great looking sling. I love the attention to detail, it looks very realistic! Also, I totally agree with ShinyRhino, throwing your mags away when they are empty is just silly. It always bugs me when they do that in video games and stuff Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5158120 Share on other sites More sharing options...
Race Bannon Posted August 31, 2018 Share Posted August 31, 2018 I Have Been Summoned Bring forth thy recipe. THIS, I COMMAND!!! Please ^_^ W.A.Rorie, MrZakalwe and duz_ 3 Back to top Link to comment https://bolterandchainsword.com/topic/339466-deployment-of-the-spectral-sicarii-homebrew-rg/page/16/#findComment-5158157 Share on other sites More sharing options...
