9x19 Parabellum Posted October 8, 2021 Share Posted October 8, 2021 There were always vows you never took, this is just another one of them. There is a difference between some selections being better than others, and "let's take a Drax style famously-huge-turd right in the middle of the Black Templar's new codex and hope they don't notice". Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751165 Share on other sites More sharing options...
Banjulhu Posted October 8, 2021 Share Posted October 8, 2021 Am I just being thick, or does Devout Push not actually let you do what their description says it should? If I'm not within engagement range, I can only make a normal move, which means I can't finish within engagement range, so no fighting. If I am already within engagement range, I can pile in, but, couldn't I do that anyway when I fight? That seems to be the correct interpretation but not necessarily the intent. Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751166 Share on other sites More sharing options...
Sword Brother Adelard Posted October 8, 2021 Share Posted October 8, 2021 I think the intent behind the rule is pretty clear, if it wasn't, that was a God awful way to draft it. Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751167 Share on other sites More sharing options...
BitsHammer Posted October 8, 2021 Share Posted October 8, 2021 ok so Suffer Not the Unclean to Live pretty much guaranteed will never be used as is. It is now the previously underwhelming Knights of Sigismund Superdoctrine, but made even worse by an absolutely horrendously egregious drawback. If you ever played Warhammer Fantasy with units that had the old Frenzy rules where you had to charge the closest enemy, well, you'll remember how easy it is for your opponent to control your army's movement/charges. I'm shaking my head in disbelief at how bad this is. Good grief. Nah, it's fine. It's not "competetive" but some people like having an excuse to turn your brain off and just charge all the time. Just ask Duncan Rhodes. Land Raiders are "not competitive". This is way, waaaay worse than "not competitive". Any rule that gives your opponent control over your army's movement is a HUGE drawback, especially when's it's dressed up in the guise of being a 'perk'. This particular vow's drawback far exceeds the benefit. Eh, it's on brand for the Templars. Fluffy rules aren't always good. If anything it may be a good choice for playing newer players and you only have one army list. Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751168 Share on other sites More sharing options...
9x19 Parabellum Posted October 8, 2021 Share Posted October 8, 2021 (edited) Also am I wrong or is Devout Push also completely neutered now? "...make a Normal Move of up to 3" This would suggest you can no longer use Devout Push to get into combat as it specifies the additional movement as a "Normal Move". You can use it to get onto objectives, but that was always available anyway. And in fact this new restricted movement means you might not be able to use Devout Push in other clever ways, such as to get a unit into cover/out of LOS, or get a unit into a table quarter for Engage All Fronts, etc. No matter how you slice it, this is a profound nerf. or "If that unit is within Engagement Range of any enemy units, make a pile-in move with that unit". So this stipulates you're already in combat (engagement), which is to say, you've successfully charged. About the only utility I can see for this is to take large units of Crusader squads and make sure as many of the models in it as possible can fight. (I assume this is essentially a 2nd pile-in move in addition to the normal pile-in you'd be allowed when you select that unit to actually fight.) I am incredulous at the neutering. Edited October 8, 2021 by 9x19 Parabellum Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751169 Share on other sites More sharing options...
Sword Brother Adelard Posted October 8, 2021 Share Posted October 8, 2021 (edited) Also am I wrong or is Devout Push also completely neutered now? "...make a Normal Move of up to 3" This would suggest you can no longer use Devout Push to get into combat as it specifies the additional as a "Normal Move". You can use it to get onto objectives. or "If that unit is within Engagement Range of any enemy units, make a pile-in move with that unit". So this stipulates you're already in combat (engagement), which is to say, you've successfully charged. About the only utility I can see for this is to take large units of Crusader squads and make sure as many of the models in it as possible can fight. I am incredulous at the neutering. Oh, at least you found one use for the double pile in. I was struggling! Yep, it's now only useful to move closer to an objective. This is what I mean when I say War Com's description of it doesn't make sense: "Devout Push enables one unit that’s run out of heretics to stay on the front foot by moving back into Engagement Range and keep the momentum going." It literally does the opposite. Edited October 8, 2021 by Brother Adelard 9x19 Parabellum 1 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751171 Share on other sites More sharing options...
Blindhamster Posted October 8, 2021 Share Posted October 8, 2021 Also am I wrong or is Devout Push also completely neutered now? "...make a Normal Move of up to 3" This would suggest you can no longer use Devout Push to get into combat as it specifies the additional movement as a "Normal Move". You can use it to get onto objectives, but that was always available anyway. And in fact this new restricted movement means you might not be able to use Devout Push in other clever ways, such as to get a unit into cover/out of LOS, or get a unit into a table quarter for Engage All Fronts, etc. No matter how you slice it, this is a profound nerf. or "If that unit is within Engagement Range of any enemy units, make a pile-in move with that unit". So this stipulates you're already in combat (engagement), which is to say, you've successfully charged. About the only utility I can see for this is to take large units of Crusader squads and make sure as many of the models in it as possible can fight. (I assume this is essentially a 2nd pile-in move in addition to the normal pile-in you'd be allowed when you select that unit to actually fight.) I am incredulous at the neutering. honestly seems like thats exactly the intent - to make the huge crusader squads able to make the most of their numbers. Trignama 1 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751176 Share on other sites More sharing options...
Marshal Reinhard Posted October 8, 2021 Share Posted October 8, 2021 Its almost as if there was something behind Laeroths "we will have to rethink" whenever rules discussions started rdvolving around DP Kastor Krieg, Marshal Laeroth, BitsHammer and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751178 Share on other sites More sharing options...
9x19 Parabellum Posted October 8, 2021 Share Posted October 8, 2021 Its almost as if there was something behind Laeroths "we will have to rethink" whenever rules discussions started rdvolving around DP Here is what I'm "rethinking". Buy BT models. Paint them black. Call them "counts as Blood Angels" :-D Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751181 Share on other sites More sharing options...
Banjulhu Posted October 8, 2021 Share Posted October 8, 2021 The thinking now being "Why would I ever bother thinking about using Devout Push?“. atropos_priest and 9x19 Parabellum 2 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751184 Share on other sites More sharing options...
Trignama Posted October 8, 2021 Share Posted October 8, 2021 (edited) I believe DP is now worded to work as intended. Basically we get to double pile in, this can be A LOT of movement when combined with Canticles of Hate (Increases pile ins to 6" movements). Before, since the move you were granted by DB was strictly a pile in move, you ALWAYS had to move towards the nearest enemy model, so yes, now that it is a normal move it does mean we can no longer use it to skirt a charge but still get into combat, HOWEVER, we can now be more flexible in it's direction if we need to hold on to an obj. So, it isn't AS GOOD, no, but it is no where near being bad, especially the extra pile in, that can swing games. Edited October 8, 2021 by Trignama Khornestar and BitsHammer 2 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751185 Share on other sites More sharing options...
Marshal Reinhard Posted October 8, 2021 Share Posted October 8, 2021 (edited) The thinking now being "Why would I ever bother thinking about using Devout Push?“. Again, almost as if he had given non-subtle hints to that effect for months now Edited October 8, 2021 by Reinhard Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751186 Share on other sites More sharing options...
9x19 Parabellum Posted October 8, 2021 Share Posted October 8, 2021 (edited) Large Crusader squads will not live long enough to see use of their design intent, which is to get into combat as a big group and clog everything up with Devout Push, slowly grinding the grist of war to attrition and victory. I'm fairly certain the Primaris "Scouts" (ie, neophytes) will be losing their smokescreen key word. I also have a sneaking suspicion we are going to get screwed with using Transhuman. They are either going to fart around with the keywords, thus preventing us from using it, or they are going to charge us more than the standard 2 CP to use it. If they also kill our 5+ FnP littany, then it's GG for Crusader Squad. Crusader Squads are a trap. Go 3x5 MSU on Troops. The best plan is the same as it has been. Bladeguard Veterans. Only difference now is you don't have to spend 130 points for an impulsor since the Devout Push bomb is DoA. Edited October 8, 2021 by 9x19 Parabellum Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751187 Share on other sites More sharing options...
Banjulhu Posted October 8, 2021 Share Posted October 8, 2021 At least the non character relics look fun. Its just a shame that so far most of the rules that have been shown off feel like sidegrades or downgrades. Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751189 Share on other sites More sharing options...
Trignama Posted October 8, 2021 Share Posted October 8, 2021 Large Crusader squads will not live long enough to see use of their design intent, which is to get into combat as a big group and clog everything up with Devout Push, slowly grinding the grist of war to attrition and victory. I'm fairly certain the Primaris "Scouts" (ie, neophytes) will be losing their smokescreen key word. I also have a sneaking suspicion we are going to get screwed with using Transhuman. They are either going to fart around with the keywords, thus preventing us from using it, or they are going to charge us more than the standard 2 CP to use it. If they also kill our 5+ FnP littany, then it's GG for Crusader Squad. Crusader Squads are a trap. Go 3x5 MSU on Troops. The best plan is the same as it has been. Bladeguard Veterans. Only difference now is you don't have to spend 130 points for an impulsor since the Devout Push bomb is DoA. I'm going to laugh when this is completely and utterly wrong lol. There is nothing to suggest our FNP litany is gone, and nothing to suggest that a primaris unit won't get to use xhuman for 2cp as it works now. We are close enough to release that I think we would have caught wind of that. I also highly doubt that GW is going to make a brand new space marine core unit for a brand new release, bad. BitsHammer 1 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751191 Share on other sites More sharing options...
Sword Brother Adelard Posted October 8, 2021 Share Posted October 8, 2021 While not Core, have you seen any Gladiators around since their release...? Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751194 Share on other sites More sharing options...
Trignama Posted October 8, 2021 Share Posted October 8, 2021 While not Core, have you seen any Gladiators around since their release...? Actually, I use one personally, and it doesn't perform half bad. Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751195 Share on other sites More sharing options...
9x19 Parabellum Posted October 8, 2021 Share Posted October 8, 2021 (edited) <snip> I'm going to laugh when this is completely and utterly wrong lol. There is nothing to suggest our FNP litany is gone, and nothing to suggest that a primaris unit won't get to use xhuman for 2cp as it works now. We are close enough to release that I think we would have caught wind of that. I also highly doubt that GW is going to make a brand new space marine core unit for a brand new release, bad. What exactly do you think I'm wrong about? A big crusader squad is going to be minimum 400 pts. probably more with guns and upgrades. A unit that big will be the focal point for support, so all the HQ characters will be built around supporting it. Add in that character support and you're looking at an all-in of ~700 points based around this unit. It can't go into LCC anymore because <PRIMARIS>, which means it's foot-slogging. I suppose you could "Outflank" it (stratagem), but at 20 CP it will cost 3 CP. It's going to be a VERY big footprint, which means keeping it out of LOS is not possible. YWhile you should be able to get soft cover, the LOS issue means literally your opponent's entire army will focus on it. -There is nothing in the Neophyte modeling to suggest smokescreen, nor is that a fluffy tactic for BT. I will bet my next paycheck that they are losing <SMOKESCREEN> -While I admit to a bit of "sky is falling" regarding the 5+ FnP littany, so far it seems they have been hitting all our best stuff from 8th edition with the nerf bat, either lightly or heavily, but hitting it with the nerf bat nonetheless. -Re: Transhuman....what are you on about?? The Stratagem literally specifies 1 CP for 5 models, and 2 CP for up to 10. The only reason it didn't go beyond that is because when it was written, there was no paradigm for Primaris units ever having more than 10 models. You really think they are going to let us off with a 20 MAN unit, and not modify the CP expenditure for it? As for your last bit: I also highly doubt that GW is going to make a brand new space marine core unit for a brand new release, bad. You're just really not watching GW's releases if you think this is true. There is virtually no corollary between "new stuff" and being "good". Reivers are still garbage 3 years after they came out. Gladiators are garbage. The SoB Castigator is garbage. SoB Paragon Warsuits are...not garbage but certainly overpriced. Sometimes stuff is good, sometimes it's not. Edited October 8, 2021 by 9x19 Parabellum Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751197 Share on other sites More sharing options...
Sete Posted October 8, 2021 Share Posted October 8, 2021 I see we are at the phase of moaning about rules? Cool cya guys laterz Hidenheart, Marshal Mattias, Mmmmm Napalm and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751206 Share on other sites More sharing options...
9x19 Parabellum Posted October 8, 2021 Share Posted October 8, 2021 I see we are at the phase of moaning about rules? Cool cya guys laterz yes. You're welcome back any time, though. Sete 1 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751211 Share on other sites More sharing options...
Sword Brother Adelard Posted October 8, 2021 Share Posted October 8, 2021 I see we are at the phase of moaning about rules? Cool cya guys laterz To be fair, I'm moaning about War Com's inability to understand their own rules. Sete and 9x19 Parabellum 2 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751219 Share on other sites More sharing options...
Tokugawa Posted October 8, 2021 Share Posted October 8, 2021 (edited) Grimaldus is power level 7? Which hints ~140pts... And 4 sword brethrens is also power level 7, so ~35pts per guy(maybe include the weapons). But the name of their swords is "power sword", not "master crafted power sword". So they can't compete with on defence, then they can't compete with BGV on offence, too. Edited October 8, 2021 by Tokugawa Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751227 Share on other sites More sharing options...
Marshal Laeroth Posted October 8, 2021 Share Posted October 8, 2021 So I have stayed away and not dropped any further hints on here, as per request. But I did say that we were going to need to adapt. I did not say we were going to be less competitive. Just consume the book, let your emotions idle down a little...and you'll be able to see the delicious combos. You have to remember...I have had access to the rules for quite some time. I am a very competitive player. That's what I do. And I am excited for our future. Marshal Valkenhayn, atropos_priest, redmapa and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751234 Share on other sites More sharing options...
Marshal Mattias Posted October 8, 2021 Share Posted October 8, 2021 C'mon everyone, usually we wait until the whole rulebook is out before we start claiming the sky is falling Let's show a little faith, eh? Sete 1 Back to top Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751239 Share on other sites More sharing options...
Odd-ad Posted October 8, 2021 Share Posted October 8, 2021 I was going to say, we should have learned by now that we really can't make judgement calls either way about rules or units until we have all the information. How many times have players been up in arms about rules that seem to be too powerful or too weak, only to later learn that the outrage was overblown. Link to comment https://bolterandchainsword.com/topic/370962-black-templar-teaser-and-rumors/page/86/#findComment-5751240 Share on other sites More sharing options...
