WarriorFish Posted April 10, 2018 Author Share Posted April 10, 2018 Thanks hush, I'm really pleased with his progress so I'm keen to get more painting done Astrogranite is one of GWs newish texture paints, there's also the thicker version of Astrogranite Debris which I've just used for the first time on the Daemon Prince's base. I quite like the texture paints as something a bit different for bases and they make it easier to get certain looks. There's quite a few different types of texture paints so they're worth a look if you've not done so Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5052178 Share on other sites More sharing options...
hushrong Posted April 10, 2018 Share Posted April 10, 2018 (edited) Is that what you have on the base by the DP's right foot? if so I may invest in some. Too many times I tried making a slush of glue and sand to do something similar and each time was no bueno. Edited April 10, 2018 by hushrong Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5052201 Share on other sites More sharing options...
WarriorFish Posted April 10, 2018 Author Share Posted April 10, 2018 It is yes, you can see the difference easiest in this picture: At the back, round the edge is the thicker Astrogranite Debris. Towards the centre/above the ruin piece is the normal Astrogranite which is not as thick and more granular in how it works. I think all of the texture paints have a normal/thick version so there's plenty of variety especially as the thicker version can be more than the same but, well, thicker For example I use the Martian texture pair for my Dark Eldar in a similar way to the above, the Ironearth gives quite a different texture but as the same base approach (and importantly - colour) it can make bases go quite far in variety without much effort Attack with different washes and highlighting and you can tweak the colours quite a bit too :tu: Kierdale, Commander Dawnstar and Arkaniss 3 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5052213 Share on other sites More sharing options...
Gederas Posted April 10, 2018 Share Posted April 10, 2018 Something I've been wondering: As I thought the DE were a good source - left overs from a Wyche box had a sword that I could quickly chop into size: So that sword is specifically from the Dark Eldar Wych kit? 'cause I was also thinking of using Escher gangers for some of my Slaaneshi cultists, and needed something for the Cultist Champion. Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5052313 Share on other sites More sharing options...
hushrong Posted April 10, 2018 Share Posted April 10, 2018 I like that astrogranite. I think that is going on my grocery list for GW. I think it will apply it to the base of the minis before doing priming and just paint over it. Or is that just dumb-ish? The curved dark elder blades just ooze a Slaaneshi vibe and does look nice. I've been using those Black Ark DE for their weapons on some of my older Emperor's Children. Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5052368 Share on other sites More sharing options...
WarriorFish Posted April 10, 2018 Author Share Posted April 10, 2018 So that sword is specifically from the Dark Eldar Wych kit? 'cause I was also thinking of using Escher gangers for some of my Slaaneshi cultists, and needed something for the Cultist Champion. You can see it on the sprue, just in from the top left I removed the power pack bit and handle to fit. I like that astrogranite. I think that is going on my grocery list for GW. I think it will apply it to the base of the minis before doing priming and just paint over it. Or is that just dumb-ish? You'd have to paint it up which would be more work of course, but if you're after the texture rather than the colour it should be fine Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5052407 Share on other sites More sharing options...
Sagentus Posted April 12, 2018 Share Posted April 12, 2018 That dp is looking great. I like the red/white armour, it looks like a recent space marine has joined the dark side WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5054177 Share on other sites More sharing options...
WarriorFish Posted April 13, 2018 Author Share Posted April 13, 2018 Thanks Sagentus, that's what I'm aiming for Here he is in all his fiendish glory: Pleased with how he's turned out, and as an added bonus the GSing went so well I forgot I even did it when painting I've got the backpack vents and sword to do, but this will be his main build so there's no particular rush to finish them. I'll focus on the Cultists next, though when I'm not painting I'll be assembling the Maulerfiend... Panzer, ChazSexington, Pearson73 and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055032 Share on other sites More sharing options...
Panzer Posted April 13, 2018 Share Posted April 13, 2018 One of my favorite Daemon Princes I've seen so far. Not lying. WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055034 Share on other sites More sharing options...
Kierdale Posted April 13, 2018 Share Posted April 13, 2018 Splendid! :tu: The colours work well on him and the faceless mask is a particularly good choice. WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055117 Share on other sites More sharing options...
Pearson73 Posted April 14, 2018 Share Posted April 14, 2018 Cracking work, once again, I really must compliment the choice of colours; the faceless mask gives him a very unique appearance too. WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055205 Share on other sites More sharing options...
WarriorFish Posted April 14, 2018 Author Share Posted April 14, 2018 Thanks guys, my first finished Daemon unit so technically the start of the Daemons army! I'll be giving him friends soon enough :) Now I need to work him into a list as I creep closer to that 1500pts game :D Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055216 Share on other sites More sharing options...
WarriorFish Posted April 15, 2018 Author Share Posted April 15, 2018 Time for another first: the Sunder's first vehicle! This is assembled as it'll get, I'll paint it up then have the fun of sticking it to the base and all the basing. Should mean plenty of opportunity to spruce the base up though Tentacles (official: said so on the instructions) are just in place in the picture, which is how they'll stay otherwise the model will never get transported Speaking of instructions; good job I didn't want the plasma cutters as there's not mention of them on the booklet? The bits exist but I've no idea how they're supposed to work, seems a bit basic to just have them slot into the tentacle bit? If that's so then I'll do a bit of magnetising to have my cake and eat it. Cultists are still on the cards, but wasn't in the mood for painting today. Should be able to swap between them for detail/basic work depending on how I feel once I undercoat the Maulerfiend Arkaniss 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055964 Share on other sites More sharing options...
WarriorFish Posted April 15, 2018 Author Share Posted April 15, 2018 After some searching I managed to find a close up image of the magma cutters, turns out there was only one extra bit on top which was nice and simple. That means it's magnetising time Does a good crab impression. It was a bit interesting getting the internal magnets in, felt like it was the final boss level of Operation The lasher tendrils should hold in by themselves wither their tabs and the extra layers from the primer and some paint but if not it won't be too much work to add a magnet in Kierdale and Arkaniss 2 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055995 Share on other sites More sharing options...
Panzer Posted April 15, 2018 Share Posted April 15, 2018 I wish the Magma Cutters wouldn't suck so hard. Anyway, looking forward to what you're doing with the model. The Maulerfiend is one of my favorite models in 40k. ^^ WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5055999 Share on other sites More sharing options...
WarriorFish Posted April 15, 2018 Author Share Posted April 15, 2018 Indeed, but I thought that for not much extra work no harm in having options and they might get improvement in the future I've enjoyed building the kit (poor Cultists may suffer more for it...) and it looks great - enough to consider getting a second, but as it's quite restrictive in pose I'd need to get converting to give them some difference. That's assuming I finish the model, maybe I did get too much sun yesterday but I'm finding this far more amusing than I should: Hidden Content Maulershrimp! It's too late; you've seen it and can't take it back Arkaniss and Tallarn Commander 2 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5056031 Share on other sites More sharing options...
hushrong Posted April 16, 2018 Share Posted April 16, 2018 In your latest picture I see a crustacean that makes me think "Nah. Nope. Not today." Looking forward to progress on this big stomper. WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5056450 Share on other sites More sharing options...
Panzer Posted April 16, 2018 Share Posted April 16, 2018 It does look like some deep sea creature, doesn't it? Suitable for the Mare Solum facebook group (lots of water themed army projects). :D hushrong 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5056459 Share on other sites More sharing options...
hushrong Posted April 16, 2018 Share Posted April 16, 2018 Sand Fleas! That's what it reminds me of...just the hell version of one. Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5056461 Share on other sites More sharing options...
Arkaniss Posted April 18, 2018 Share Posted April 18, 2018 Daemon prince looks amazing! I like the blue and green daemon arm eyes too, matching the lenses :D How about a group shot of him with some Sunder Marines? The Maulerfield looks like a good kit but I am sad you've still not done a Rhino chassis vehicle. I will keep the candle burning :P WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5059237 Share on other sites More sharing options...
WarriorFish Posted April 18, 2018 Author Share Posted April 18, 2018 I'll have an opportunity for an army shot next week Rhino will be done after the Cultists, as I'll need more vehicles to help the Maulerfiend so it doesn't eat all the AT For future vehicular additions, a Heldrake and another Rhino are probably next. The tweaks to Chosen have me more interested in them, but I'll cross that bridge once I've got the Havoc squads sorted and some Raptors so no rush there. Been a bit busy so not much progress to report, hopefully get some more done on the Cultists this week! Tallarn Commander and Arkaniss 2 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5059251 Share on other sites More sharing options...
Kierdale Posted April 18, 2018 Share Posted April 18, 2018 For Raptors are you planning on using the CSM kit? Loyalist assault marines? Something from FW? A delightful mix?? Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5059353 Share on other sites More sharing options...
WarriorFish Posted April 18, 2018 Author Share Posted April 18, 2018 I'm not sure yet, as the Sunder are bashed together from many kits I'll probably do the same again. I've got jump packs from the Sanguinary Guard which I'll use to keep the MkIV theme strong and make them a little different. I'll raid FW for some assault MkIV Marines to spice them up and get more running legs (always harder to find!) Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5059407 Share on other sites More sharing options...
Kierdale Posted April 18, 2018 Share Posted April 18, 2018 Keep the Sanguinary wings for Warp Talons and give the Raptors regular jump packs? If only Warp Talons were better... :( Gederas 1 Back to top Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5059520 Share on other sites More sharing options...
Gederas Posted April 18, 2018 Share Posted April 18, 2018 Keep the Sanguinary wings for Warp Talons and give the Raptors regular jump packs? If only Warp Talons were better... And now they're even worse, sadly. Link to comment https://bolterandchainsword.com/topic/298128-warriorfishs-sunder-csm/page/22/#findComment-5059534 Share on other sites More sharing options...
