Phatsquirre1 Posted November 18, 2016 Share Posted November 18, 2016 Does anyone know how to find the Praetor Tribune in the HQ section? I can't for the life of me see it anywhere. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4564992 Share on other sites More sharing options...
ezeefisch Posted November 18, 2016 Share Posted November 18, 2016 Can't find the option to give regular Apothecaries Jump Packs. You need to check the "additional wargear" option, this will then turn red indicating further options within, then select either Artificer armour, outsider bike or jump pack. Hope this helps Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4565108 Share on other sites More sharing options...
Guiltysparc Posted November 18, 2016 Share Posted November 18, 2016 Does anyone know how to find the Praetor Tribune in the HQ section? I can't for the life of me see it anywhere. He doesn't appear to be in the current gen of data files...he is in the files that worked for 1.0 though. The tribune and the praevian fix are the two things i'm most looking forward to. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4565598 Share on other sites More sharing options...
Lord_Ikka Posted November 18, 2016 Share Posted November 18, 2016 Consul Delagatus doesn't have the option for a command squad to be attached. Otherwise, looking good for me! Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4565655 Share on other sites More sharing options...
Dark Bjoern Posted November 19, 2016 Share Posted November 19, 2016 Yesterday i made an update on my tablet. Since this update BS didn´t work anymore. I removed it and installed it anew, but the error is still the same. An on PC it works with a lot of errors. Does anyone else have such problems with BS? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4566109 Share on other sites More sharing options...
Dosjetka Posted November 19, 2016 Share Posted November 19, 2016 Ultramarine Consul in Tartaros Armour has no option for the Legatine Axe. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4566439 Share on other sites More sharing options...
helterskelter Posted November 21, 2016 Share Posted November 21, 2016 Morning, sorry to add to the pile but it appears that breachers on my list are 10 points too expensive and there isn't an option for the breacher charge? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4567827 Share on other sites More sharing options...
Eternal Despair Posted November 21, 2016 Share Posted November 21, 2016 There is no option for the Praevian Consul to select a unit of Battle-automata as part of his unit Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4568145 Share on other sites More sharing options...
exsanguis Posted November 22, 2016 Share Posted November 22, 2016 Not sure if it's been mentioned already but: Hunter Killer Missiles should be 5 points Librarian Consul has no option for Mastery levels? Need Master of Armour added as a default HQ in order to unlock the AB RoW without having to add and then remove a Praetor Other than that, getting used to the new layout which generally seems to be an improvement. Keep up the good work. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4569352 Share on other sites More sharing options...
Vogon Posted November 22, 2016 Share Posted November 22, 2016 In the Alpha Legion Lernean Terminator selections if I upgrade all regular terminators to have a power fist and give one a heavy weapon I get an error telling me I've picked too many weapons I'm also getting a string of errors by adding a Leviathan Force Org and then adding Alpharius. Thanks for your hard work. Cheers Vogon. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4569362 Share on other sites More sharing options...
BLACK BLŒ FLY Posted November 22, 2016 Share Posted November 22, 2016 Command squads have access to jump packs, right ? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4569564 Share on other sites More sharing options...
Anvilarium Posted November 22, 2016 Share Posted November 22, 2016 When I have 1 x Praetor (with Honor Guard) and 2 x Consuls (1 x Librarian, 1 x Master of the Forge) and use the X: Iron Hands Legion and Head of the Gorgon RoW, I'm getting an error message which says that I am only allowed 1 Consul.. Pretty sure this is incorrect - the Honor Guard do not count as a seperate HQ Slot do they? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4569613 Share on other sites More sharing options...
MadHatter5045 Posted November 22, 2016 Share Posted November 22, 2016 I still haven't figured out how to use RoW or Lords of War at all in the new mobile version. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4569658 Share on other sites More sharing options...
Phatsquirre1 Posted November 22, 2016 Share Posted November 22, 2016 Can't seem to find The Sky-Slayer Jetbike Squadron in the HS section. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4569936 Share on other sites More sharing options...
RandomMarine Posted November 23, 2016 Share Posted November 23, 2016 Same here no skyhunters and my fa slot disappears when I select hotg ROW Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4570264 Share on other sites More sharing options...
Marshal Loss Posted November 23, 2016 Share Posted November 23, 2016 Anybody else getting the error message where it says I've spent too many points on Lords of War, despite having the right detachment selected and no Lords of War used anywhere? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4570348 Share on other sites More sharing options...
helterskelter Posted November 23, 2016 Share Posted November 23, 2016 Anybody else getting the error message where it says I've spent too many points on Lords of War, despite having the right detachment selected and no Lords of War used anywhere? Ah see I thought I'd just pressed the wrong button. Yeah I've been getting that Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4570361 Share on other sites More sharing options...
IronDrake28 Posted November 23, 2016 Share Posted November 23, 2016 Ditto. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4570468 Share on other sites More sharing options...
RandomMarine Posted November 23, 2016 Share Posted November 23, 2016 I get that in every other list. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4570929 Share on other sites More sharing options...
TheDecay Posted November 23, 2016 Share Posted November 23, 2016 Adding to the pile...the Landraider Proteus doesn't have the option to select a hull mounted lascannon which I'm pretty sure it got in the most recent update.Thanks for the hard work! Much appreciated Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4570954 Share on other sites More sharing options...
ezeefisch Posted December 1, 2016 Share Posted December 1, 2016 Couple more to add to the list, Still getting the error for "list had spent 1875pts too much on LoW" Legion jetbike sky slayer squadron are missing from the heavy support section Getting an error Fast Attack has 1 too many selections from Anvillus Pattern Dreadclaw Drop pod (maximum 1) When I add two to my fast attack choice. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4579006 Share on other sites More sharing options...
ShadowCore67 Posted December 1, 2016 Share Posted December 1, 2016 Another one to add to the list, Shadrak Meduson isn't showing the option to take a command squad. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4579091 Share on other sites More sharing options...
Marshal Loss Posted December 7, 2016 Share Posted December 7, 2016 Forgive me if this a known issue/intentional, but the most irritating thing about having to get another detachment in order to select a Lord of War is that if I"m making a list and a Primarch is my Master of the Legion, having him in another detachment means that I can't select a Rite of War in my primary, which really hampers list building. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4584903 Share on other sites More sharing options...
Lord-Enki Posted December 9, 2016 Share Posted December 9, 2016 Knights-Errant seem to be excluded from every list other than Legiones Astartes. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4587945 Share on other sites More sharing options...
Krikey Posted December 9, 2016 Share Posted December 9, 2016 Is anyone we having difficulty with the iOS versions crashing? I've tried on my iPad and on my iPhone -- I have the same problem with each. When I try to load a roster, the app crashes out and sends me back to my home screen. ~K Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/38/#findComment-4588264 Share on other sites More sharing options...
