Ancient_Sobek Posted September 8, 2021 Share Posted September 8, 2021 I’m open to suggestions on what gear to requisition Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739851 Share on other sites More sharing options...
A.T. Posted September 8, 2021 Share Posted September 8, 2021 Odysseus will likely retain his flamer for the time being (10 requisition), or upgrade to the more potent immolation rifle (15 requisition). His remaining goes into the squad pot. Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739854 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2021 Share Posted September 8, 2021 @ Sobek, there's the Power Axe or Power Sword? Both 20 Req, Respected Renown. Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739856 Share on other sites More sharing options...
Trokair Posted September 8, 2021 Share Posted September 8, 2021 @ Tro, I'd look into the Auxiliary Grenade Launcher if I were you. You could combine it to your bolter or have it as a standalone. I think it's 15 Req, Respected, and there's a profile for it on the 1.1 FAQ. You can fire any grenade of your choosing. Thanks for the idea, found it in the FAQ 1.1. Some follow up questions: A s far I can tell its main advantage is that it has a range of 45 compared to the SBx3 for throwing a grenade (which works out at a range of 36 if I am doing it right). Are 9 m range that critical? It also has Class N/A, how does that work into things compared Basic or Thrown? If it is combined with my bolter does that mean I can fire both as one action or would it simply become an alternate profile that I can chose when firing so I don’t have to swap back and forth between holding the bolter and having a free hand to throw with? Lastly it says that it has a clip size of 4, does that mean it comes with 4 grenades already loaded (I’d assume either of the basic ones) or just that I can pre load up to 4 grenades I have on me. I am apparently and very sadly out of likes! A common affliction in these parts, join the club. Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739860 Share on other sites More sharing options...
Black Cohort Posted September 8, 2021 Share Posted September 8, 2021 If I can get an extra 5 requisition, I can take a suspensor for my heavy bolter, which increases my ability to move and fire. Machine God and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739871 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2021 Share Posted September 8, 2021 (edited) Thanks for the idea, found it in the FAQ 1.1. Some follow up questions: A s far I can tell its main advantage is that it has a range of 45 compared to the SBx3 for throwing a grenade (which works out at a range of 36 if I am doing it right). Correct Are 9 m range that critical? Your call... It also has Class N/A, how does that work into things compared Basic or Thrown? Basic - it combines with your bolter, counting as one weapon, or it's a Basic if a standalone. If it is combined with my bolter does that mean I can fire both as one action No or would it simply become an alternate profile that I can chose when firing so I don’t have to swap back and forth between holding the bolter and having a free hand to throw with? Correct Lastly it says that it has a clip size of 4, does that mean it comes with 4 grenades already loaded Correct (I’d assume either of the basic ones Correct) or just that I can pre load up to 4 grenades I have on me. Happens on reload, so technically you carry your normal bomb load, plus the four in your launcher. Edited September 8, 2021 by Mazer Rackham Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739873 Share on other sites More sharing options...
Lysimachus Posted September 8, 2021 Author Share Posted September 8, 2021 Ok, I think I've shared with the right 10 emails :D Anyone who didn't get it let me know? Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739883 Share on other sites More sharing options...
Trokair Posted September 8, 2021 Share Posted September 8, 2021 Thanks for the idea, found it in the FAQ 1.1. Some follow up questions: A s far I can tell its main advantage is that it has a range of 45 compared to the SBx3 for throwing a grenade (which works out at a range of 36 if I am doing it right). Correct Are 9 m range that critical? Your call... It also has Class N/A, how does that work into things compared Basic or Thrown? Basic - it combines with your bolter, counting as one weapon, or it's a Basic if a standalone. If it is combined with my bolter does that mean I can fire both as one action No or would it simply become an alternate profile that I can chose when firing so I don’t have to swap back and forth between holding the bolter and having a free hand to throw with? Correct Lastly it says that it has a clip size of 4, does that mean it comes with 4 grenades already loaded Correct (I’d assume either of the basic ones Correct) or just that I can pre load up to 4 grenades I have on me. Happens on reload, so technically you carry your normal bomb load, plus the four in your launcher. Can it be added to a bolt pistol, and if so can I then shoot krak grenades in melee/combat? :P Unless there is something else that the auxiliary grenade launcher dose that I am not comprehending then effectively paying 11 Req for 9 m range seems like an overly expensive upgrade. Not finalized but leaning towards 15 Req worth of Frag and Krak, and giving 5 to help Decimus. Lysimachus, for episode 1 you allowed me to take at 1 Req each 3 extra frag and 2 extra krak, I assume the same applies here, but just wanted to check in case there was a limit you wanted to set for how many grenades Brynjarr can fit in his bandolier (or his person in general). Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739887 Share on other sites More sharing options...
Beren Posted September 8, 2021 Share Posted September 8, 2021 Placeholder filled. Looking at 2 demo charges for req. Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739888 Share on other sites More sharing options...
Commissar Molotov Posted September 8, 2021 Share Posted September 8, 2021 Requisition updated. As a bolter-wielder I'm somewhat limited in my stopping power. If there is 8 req at the end I'd like to stake my claim for improving the craftsmanship of my bolter. Happy either way though. Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739890 Share on other sites More sharing options...
Necronaut Posted September 8, 2021 Share Posted September 8, 2021 Requisition updated. As a bolter-wielder I'm somewhat limited in my stopping power. If there is 8 req at the end I'd like to stake my claim for improving the craftsmanship of my bolter. Happy either way though. Meltagun! Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739895 Share on other sites More sharing options...
Machine God Posted September 8, 2021 Share Posted September 8, 2021 Spreadsheet updated. Draak: Recoil Baffling 10 Req Astartes Melee Attachment (Chain Axe) 9 Req Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739903 Share on other sites More sharing options...
Ancient_Sobek Posted September 8, 2021 Share Posted September 8, 2021 A power sword works for me Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739904 Share on other sites More sharing options...
Necronaut Posted September 8, 2021 Share Posted September 8, 2021 I like how we're about to leave to infiltrate two planets to talk to some people, yet we're gearing up like we're going to purge a hive of heretics. #astarteslogic Ancient_Sobek 1 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739906 Share on other sites More sharing options...
Ancient_Sobek Posted September 8, 2021 Share Posted September 8, 2021 We are just hammers who see nails everywhere we go... Necronaut 1 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739907 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2021 Share Posted September 8, 2021 (edited) Unless there is something else that the auxiliary grenade launcher dose that I am not comprehending then effectively paying 11 Req for 9 m range seems like an overly expensive upgrade. Actually I made a mistake here - I forgot that since the grenade launcher becomes a basic weapon, it benefits from Range modification, so +30 at point-blank, and range up 90 metres without penalty, only hitting -10 at 91m and -30 at 136m. Just to clear that up. I'm rusty, I admit it! I do prefer the idea of Brynjarr wandering around carry crates of grenades. @Necro - shush! Meltaguns! Besides, it's a stealth mission if no-one is alive to witness it, or in my mind at least, we are ready for when it all goes horribly, horribly wrong... @Sobek, true, true. Except you're more a tin opener looking for cans of spam... Edited September 8, 2021 by Mazer Rackham Ancient_Sobek, Trokair and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739908 Share on other sites More sharing options...
Necronaut Posted September 8, 2021 Share Posted September 8, 2021 We are just hammers who see nails everywhere we go... When in doubt, apply more chainsword. Ancient_Sobek 1 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739911 Share on other sites More sharing options...
Necronaut Posted September 8, 2021 Share Posted September 8, 2021 A more pertinent question occurs: how do we want to divide up the squad? It would seem the Traveller will be heading up the grocery/revenge mission, but what of the rest of us? Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739914 Share on other sites More sharing options...
Black Cohort Posted September 9, 2021 Share Posted September 9, 2021 Decimus does have hatred Inquisition which may be useful dealing with the revenge mission Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739915 Share on other sites More sharing options...
Lysimachus Posted September 9, 2021 Author Share Posted September 9, 2021 @Tro: OK, let me think a mo. You get three of each as standard kit, and you had an extra 3 and 2 last time, yeah? So 11 in total... I think 15 in total seems about as high as I'd go for carrying limits, does that seem reasonable? (I'm trying to think how many I could stick on a miniature without it looking ridiculous... :P ) So you'd have your 6 free ones plus could Req 9 more. Since Frags and Kraks are cheap, that would still leave 11 Req left over? Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739960 Share on other sites More sharing options...
Commissar Molotov Posted September 9, 2021 Share Posted September 9, 2021 Machine God: I had a look at Draak's post in the character thread - you mention that you were planning to update it, but at the moment I'm not sure how your armour would stick out any more than any of the other assembled Astartes? Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739970 Share on other sites More sharing options...
Trokair Posted September 9, 2021 Share Posted September 9, 2021 (edited) @Tro: OK, let me think a mo. You get three of each as standard kit, and you had an extra 3 and 2 last time, yeah? So 11 in total... I think 15 in total seems about as high as I'd go for carrying limits, does that seem reasonable? (I'm trying to think how many I could stick on a miniature without it looking ridiculous... ) So you'd have your 6 free ones plus could Req 9 more. Since Frags and Kraks are cheap, that would still leave 11 Req left over? Plus the two photon flash grenades for a total of 13 in episode 1. If 15 is the limit that feels right for you than 15 it shall be. This and Mazers post has me considering the Auxiliary Grenade Launcher again, having a range of 90m without penalty as a basic action could be useful. Also between the 15 Req for it (and the 4 grenades it brings with it) and the reaming 5 req for grenades and the starting amount I would be at exactly 15 grenades. However then I would not be able to help Decimus get the suspensor for his heavy bolter. Choices choices. I like how we're about to leave to infiltrate two planets to talk to some people, yet we're gearing up like we're going to purge a hive of heretics. #astarteslogic Says the person obsessed with everybody taking Meltaguns. A more pertinent question occurs: how do we want to divide up the squad? It would seem the Traveller will be heading up the grocery/revenge mission, but what of the rest of us? How are we getting onto either planet? Brynjarr can pilot a shuttle craft or similar if needed. Edited September 9, 2021 by Trokair Necronaut 1 Back to top Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5739981 Share on other sites More sharing options...
Machine God Posted September 9, 2021 Share Posted September 9, 2021 (edited) @Tro: OK, let me think a mo. You get three of each as standard kit, and you had an extra 3 and 2 last time, yeah? So 11 in total... I think 15 in total seems about as high as I'd go for carrying limits, does that seem reasonable? (I'm trying to think how many I could stick on a miniature without it looking ridiculous... ) So you'd have your 6 free ones plus could Req 9 more. Since Frags and Kraks are cheap, that would still leave 11 Req left over? Plus the two photon flash grenades for a total of 13 in episode 1. If 15 is the limit that feels right for you than 15 it shall be. This and Mazers post has me considering the Auxiliary Grenade Launcher again, having a range of 90m without penalty as a basic action could be useful. Also between the 15 Req for it (and the 4 grenades it brings with it) and the reaming 5 req for grenades and the starting amount I would be at exactly 15 grenades. However then I would not be able to help Decimus get the suspensor for his heavy bolter. Choices choices. A.T. said that Odysseus would be leaving 5 Req free for the pot. Edited September 9, 2021 by Machine God Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5740000 Share on other sites More sharing options...
Lysimachus Posted September 9, 2021 Author Share Posted September 9, 2021 Doh! Thanks MG, I dont think I answered that one. AT, if you want the immolation rifle, that's cool with me. And yep, that would still leave 5 extra for Decimus to get the Suspensor... Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5740009 Share on other sites More sharing options...
Machine God Posted September 9, 2021 Share Posted September 9, 2021 Also another question is: What are we going to do about our armour? It's all painted different with no uniformity and no Chapter Markings. Link to comment https://bolterandchainsword.com/topic/369913-to-plunder-the-stars-themselves-ooc-thread/page/37/#findComment-5740010 Share on other sites More sharing options...
