Lysimachus Posted March 24 Share Posted March 24 20 hours ago, Mazer Rackham said: ...you've only got 2 IP's as well, so only two requests can be made IIRC. Ah, this is what I was asking about earlier, with regard to how many items we can try to Acquire at any given point... I've tried (and failed) for 2, but I've got 3IP, so I could have a go for 1 other thing, right? Necronaut, Xin Ceithan and Mazer Rackham 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162305 Share on other sites More sharing options...
Mazer Rackham Posted March 24 Author Share Posted March 24 (edited) 23 minutes ago, Necronaut said: ...to be similarly tied into Ukalegon's power pack via Power Supply Tampering, if permissible... Regrettably, it is not. A fusion power plant does not, under normal conditions, produce promethium fuel, good sir. A Flamer may give Energy damage, but does not use it as fuel. 23 minutes ago, Necronaut said: (happy to have this set up in such a way that I would have to choose to use either the infernus pistol or hand flamer in a round but not both simultaneously) On my reading, unless you have TWWB then you wouldn't be able to anyway. Still need the prereq to shoot with both hands, and you don't have OHBD in this game. Plus you can't Quickdraw your Inferno pistol because of the cable, so you'd be down to Half-Action, and you couldn't use both guns at the same time regardless, because you can't make Attack; Ranged twice in the same turn. If you want a Hand-flamer vambrace, by all means scorch your knuckles to your heart's content, but it will have to reload as normal. Note down on your sheet which hand it's getting bolted to, and pray it doesn't get shot. 2 minutes ago, Lysimachus said: Ah, this is what I was asking about earlier, with regard to how many items we can try to Acquire at any given point... I've tried (and failed) for 2, but I've got 3IP, so I could have a go for 1 other thing, right? Yes. Edited March 24 by Mazer Rackham Lysimachus and Xin Ceithan 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162306 Share on other sites More sharing options...
Necronaut Posted March 24 Share Posted March 24 (edited) 21 minutes ago, Mazer Rackham said: Regrettably, it is not. A fusion power plant does not, under normal conditions, produce promethium fuel, good sir. A Flamer may give Energy damage, but does not use it as fuel. On my reading, unless you have TWWB then you wouldn't be able to anyway. Still need the prereq to shoot with both hands, and you don't have OHBD in this game. Plus you can't Quickdraw your Inferno pistol because of the cable, so you'd be down to Half-Action, and you couldn't use both guns at the same time regardless, because you can't make Attack; Ranged twice in the same turn. If you want a Hand-flamer vambrace, by all means scorch your knuckles to your heart's content, but it will have to reload as normal. Note down on your sheet which hand it's getting bolted to, and pray it doesn't get shot. Yes. In rebuttal, good sir, may I direct your attention to the wording of Power Supply Tampering on p.176 of the BC CRB: "Power Supply Tampering: The Power supply of the armour has been augmented to provide more power and to output that power into attached weaponry. A character can attach any Pistol or Basic Las weapon or any Pistol Melta, Plasma, or Flame weapon (emphasis mine). That weapon no longer requires reloading, never running out of ammunition unless the power supply is disabled. Additionally, the weapon is connected by a thick cable and may not benefit from the Quick Draw Talent." Now, I agree in principle and practice that SM power supplies do not, in fact, run off of prometheum, but I just thought I'd point out that it's technically supported in the RAW. I'm flexible either way. Edited March 24 by Necronaut Lysimachus, Xin Ceithan and Mazer Rackham 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162309 Share on other sites More sharing options...
Lysimachus Posted March 24 Share Posted March 24 Hmm, let's go for something a little more reasonable... how about a Grapnel and Line, that could actually be quite useful if we need to go clambering around the platform? Acquisition Test: Rarity: Average +1 (for Good Quality, increases weight load for Astartes use) = Scarce (+0) Single: +10 Crux'as mod: +10 Inf30 +20 = 50, Roll: 37, Pass! Xin Ceithan, Mazer Rackham, Iron Father Ferrum and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162311 Share on other sites More sharing options...
Xin Ceithan Posted March 24 Share Posted March 24 I have filled the placeholder - hope it gets enough devious ideas across to keep things going Lysimachus, Necronaut and Mazer Rackham 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162318 Share on other sites More sharing options...
Iron Father Ferrum Posted March 24 Share Posted March 24 (edited) 1 hour ago, Lysimachus said: Hmm, let's go for something a little more reasonable... how about a Grapnel and Line, that could actually be quite useful if we need to go clambering around the platform? Acquisition Test: Rarity: Average +1 (for Good Quality, increases weight load for Astartes use) = Scarce (+0) Single: +10 Crux'as mod: +10 Inf30 +20 = 50, Roll: 37, Pass! I had considered one of those for myself as well. Might borrow that from you if the need arises. Edit: How my brain is envisaging Obi & Varne at the moment: Edited March 24 by Iron Father Ferrum BadgersinHills, Xin Ceithan, Mazer Rackham and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162338 Share on other sites More sharing options...
Mazer Rackham Posted March 24 Author Share Posted March 24 1 hour ago, Necronaut said: In rebuttal, good sir, may I direct your attention to the wording of Power Supply Tampering on p.176 of the BC CRB: I admire your rebuttal, sir. Defence hereby noted. 1 hour ago, Necronaut said: *RAWFARE* Emphasis mine. Doesn't quite go with: 1 hour ago, Necronaut said: ...I'm flexible either way. Now does it, you little scamp? I'm going to grant you your wish. Spoiler Xin Ceithan, Necronaut, BadgersinHills and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162339 Share on other sites More sharing options...
Necronaut Posted March 24 Share Posted March 24 (edited) I do sincerely apologize if it feels like I'm battering anyone, and I do mean anyone, about the ears with the CRB (I can't afford to cover the cost of any concussion treatments or resultant brain damage). I'm just really passionate about and have a deep affection for this deeply flawed gem of a game. Edited March 24 by Necronaut Lysimachus, Xin Ceithan, BadgersinHills and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162340 Share on other sites More sharing options...
Lysimachus Posted March 24 Share Posted March 24 (edited) Interestingly, one of the very old wargear bits for Astartes Dreadnoughts was that their Multimelta could be fired on a broad or a focused pattern, counting as a heavy flamer when on the wide setting... if you keep both pistols (but you can't fire them at the same time) you could almost fluff it as one gun with the variable focus... Or at least that the Flamer isn't firing promethium, but rather super heated air (but on a dispersed setting)? Edited March 24 by Lysimachus Iron Father Ferrum, Necronaut and Xin Ceithan 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162343 Share on other sites More sharing options...
Mazer Rackham Posted March 24 Author Share Posted March 24 Soooo, what you're telling me, is that Ukalegon is just a really frustrated and super-intense hairdresser? BadgersinHills, Necronaut, Lysimachus and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162346 Share on other sites More sharing options...
Necronaut Posted March 24 Share Posted March 24 @Mazer Rackham haters gonna hate Xin Ceithan, Mazer Rackham, Lysimachus and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162348 Share on other sites More sharing options...
Xin Ceithan Posted March 24 Share Posted March 24 16 minutes ago, Lysimachus said: Interestingly, one of the very old wargear bits for Astartes Dreadnoughts was that their Multimelta could be fired on a broad or a focused pattern, counting as a heavy flamer when on the wide setting... if you keep both pistols (but you can't fire them at the same time) you could almost fluff it as one gun with the variable focus... Or at least that the Flamer isn't firing promethium, but rather super heated air (but on a dispersed setting)? Oh, I had completely forgotten about that - that’s really a neat idea! Double points considering the first box dread metal model with a multi Mehta was the BA one IIRC, so it’s perfectly fitting for our Lamenter! ( Also edited my post - I thought Varne and Obi had taken their stroll earlier… should make more sense now ) Lysimachus, Mazer Rackham, BadgersinHills and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162349 Share on other sites More sharing options...
Mazer Rackham Posted March 24 Author Share Posted March 24 Alright gents, if you've posts or placeholders, get them in some time before tomorrow afternoon (1200hrs Zulu - GMT) and we'll kill this Session and wrap for the start of your Undertakings. Be advised I don't plan to offer much XP for this as it was a bootstrap for the next phase of Part II. XP and You: All Players recieve: 150xp Questions and shouting below as per. Necronaut, Lysimachus, Machine God and 3 others 1 5 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162360 Share on other sites More sharing options...
Necronaut Posted March 24 Share Posted March 24 Banking XP for now BadgersinHills and Xin Ceithan 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162362 Share on other sites More sharing options...
Machine God Posted March 24 Share Posted March 24 Kraggan learnt Command at a cost of 100 XP, putting him on Khorne 10. Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162367 Share on other sites More sharing options...
FabiusV4lcoran Posted March 24 Share Posted March 24 @Mazer Rackham since Atesh is ont he ship loading supplies, he has no real need to hide his mutations, right? Atesh wouldn't be ashamed of a bird beak, he'd see it as a mark of pride in a 'friendly' setting. My point being, none of the crew are gonna have serious reservations about mutants? BadgersinHills, Mazer Rackham, Necronaut and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162372 Share on other sites More sharing options...
Mazer Rackham Posted March 25 Author Share Posted March 25 17 minutes ago, FabiusV4lcoran said: My point being, none of the crew are gonna have serious reservations about mutants? None whatsoever. You don't have to hide anything on board the Razor or the Dredge. FabiusV4lcoran and Xin Ceithan 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162374 Share on other sites More sharing options...
Lysimachus Posted March 25 Share Posted March 25 7 hours ago, Necronaut said: Banking XP for now Yup, same. I did have 50 banked already so I could spend 200 on something, but Swift Attack is only 300 now Hagga is Khorne Dedicated, so I think I'll hold off for that? Xin Ceithan, Necronaut, Mazer Rackham and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162388 Share on other sites More sharing options...
Mazer Rackham Posted March 25 Author Share Posted March 25 (edited) Alright gentlemen, mission launch is in a couple of hours. Please note if you have not discussed Tertiary Objectives with me by now, it is too late - we can delay no longer. If it's any compensation, I won't be bothering overmuch with complications. The plot is locked in, and since I've heard nothing from the mortals about where they want to put down, I'm going to land them right in the capital, and since Ikka's going with the RT buyer route this would make sense. We will focus on the Mortal players first since their mission launches first. Edited March 25 by Mazer Rackham Xin Ceithan, Lysimachus and BadgersinHills 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162395 Share on other sites More sharing options...
Iron Father Ferrum Posted March 25 Share Posted March 25 Honestly, I tried to think of some kind of tertiary for this for Obi and nothing really made any sense. Sorry. Xin Ceithan, Lysimachus, Mazer Rackham and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162406 Share on other sites More sharing options...
Mojake Posted March 25 Share Posted March 25 Final Acq test: Acquisition (Reaper Autocannon) Disposition (-10) 3 Infamy Points (+30) Extremely Rare (-30) Single Item (+10) Poor Quality (+10) Infamy: 30 Target: 40 Roll: 23 (Pass) Spoiler Rules Q: Since I passed by enough to not actually need to go Poor Quality, do I find one that's Common? I'm guessing not - made my bed and all that Mazer Rackham, Necronaut, Lysimachus and 2 others 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162408 Share on other sites More sharing options...
Necronaut Posted March 25 Share Posted March 25 Oh heck I knew I was forgetting to do something. Whoops. Mazer Rackham, BadgersinHills and Xin Ceithan 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162409 Share on other sites More sharing options...
Mazer Rackham Posted March 25 Author Share Posted March 25 (edited) 9 minutes ago, Iron Father Ferrum said: Honestly, I tried to think of some kind of tertiary for this for Obi and nothing really made any sense. Sorry. Seriously don't sweat it. We're still early enough in the game for Player to plot. Some of you have ideas for where you want to go, others don't. TBF, for Undivided, not plotting anything makes more sense character wise. Having said that - take a look at Obi and have a think about how he would like to progress. Tertiaries can come from anywhere, so perhaps an agreement with Varne about watching his back, or maybe there's someone who represents the face of what Obi hates, he'd like to kill them, that kind of thing. Hide contents Rules Q: Since I passed by enough to not actually need to go Poor Quality, do I find one that's Common? I'm guessing not - made my bed and all that Afraid so. We shall now dub this mighty new weapon, the 'JamCannon'. It does not fire fruit preserve, but may the dice gods preserve us all from the indiscriminate injustice it will no doubt mete out. Edited March 25 by Mazer Rackham Xin Ceithan, Iron Father Ferrum and Mojake 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162410 Share on other sites More sharing options...
Mojake Posted March 25 Share Posted March 25 I also completely forgot about tertiaries, we don't handle them in the RAW way in my home game so it slipped my mind completely. BadgersinHills, Xin Ceithan and Mazer Rackham 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162411 Share on other sites More sharing options...
A.T. Posted March 25 Share Posted March 25 Despite his terrible FEL characteristic I feel Xerxes might benefit from spending his accumulated 200xp on Deceive, before he gets everyone into trouble... Xin Ceithan, Mazer Rackham, Machine God and 1 other 1 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/112/#findComment-6162412 Share on other sites More sharing options...
